gear junkie!!
  • gear junkie!!
    your armed forces, have you ever seen a jet pump?
    that's what they call them up here.
    Vince
    Re: gear junkie!!
    You're refering to well pumps? We're taught about them but realistically they don't get used very much. All we use are 5hp sumbersible centrifical pumps.
      Re: gear junkie!!
      no, i'm talking about the pumps used on a C-130 herc.
      they hook up a high pressure hose (3") from the aircraft's apu to the pump. the pump itself looks like a huge turbo charger.
      they pump fast and loud like a jet.
      Vince
        Re: gear junkie!!
        I'm picturing some type of accessory attachment,like a P.T.O. on the hydrolic system of a tractor.
          Re: gear junkie!!
          Originally posted by Big Jim
          Would that be the JATO (Jet Assisted Take Off) system?
          You see the C-130 fall 20' out of the sky and snap it's wings off.It was supposed to land inside a football stadium to rescue the hostages in the Carter era.
          The military sure had it's problems back then.
          Two rescue missions(at least)failed.
            Re: gear junkie!!
            This is what I know about a c-130.
            -loud
            -freezing cold
            -cramped
            My only experience is as a passenger. I know more about marines and army then the navy. Just the way seabees operate.
              Re: gear junkie!!
              i'm trying to find info on the pump.
              please BEAR with me.
              Vince
