Have you seen this befor?
  • Have you seen this befor?
    I went to a customer today who had a fill valve with what looked like a stub out at the top. The customer had been told it was used to regulate the water pressure, but being they had a prv and water pressure was like 45 and when i shut the water off to the toilet the pressure didnt go up.
    i figured that some one had just made up a story about it, have any of u seen or heard of a fill valve that allso was used to regulate water pressure
    Re: Have you seen this befor?
    YES IT'S A WATT'S GOV. 80 BALLCOCK
    FOR THERMAL EXPANSION,
    IT RELIEFS AT 80 PSI. PER CODE
    FOR WHEN YOU DON'T WANT OR CAN'T INSTALL
    A REGULAR THERMAL EXPANSION TANK,
    I HAVE USED THEM ON WTR/HTR INSTALLS
    TO KEEP PRICE DOWN
    JERRYMAC
    E-MAILJERRYMAC777@GMAIL.COM
    FIRE SPRINKLER CONTRACTOR,
    SINCE JAN. 1989
      what jerry mac said its a gov. 80
      Mike
      www.plumbinginclarkcounty.com
