sleeving waterlines
  • sleeving waterlines
    On a suspended slab when running waterlines in the slab how do you guys do it?
    Re: sleeving waterlines
    Which code are you under. The ipc is specific when it comes to sleeving pipe. Look in your code book under pipe protection.
      Usually do not run anything in a slab( other than hydronics) only thru it.
        in rhode island we only run copper water lines in the slab with armoflex insulation around it not the split type either. but i still dont recomend it
