Sealing escutcheon plates
  • Sealing escutcheon plates
    I've always used a thick ring of plumbers putty behind the plates leaving a gap at the bottom for all my plates and then put a thin layer of silicone caulk around the plate except for the bottom. I always thought this is how everyone did it until a plumber asked me what I was doing when he saw me tear out the foam backing of the escutcheon plate. Do you do the same?
    Re: Sealing escutcheon plates
    If the plumber who did my bathroom took the same care you did, I would have one less hole in my laundry room ceiling.
      I will from now on ! Thank You Master
        the majority of high quality fixtures come with a foam strip. keep it there.
        i use a color matched latex with silicon caulk. i will put a bead half under the edge of the plate and let it ooze out.
        problem with putty is that fancy homes have natural stone, marble and it's a no,no to put putty against it.
        plus putty has no adhesive properties.
          I heard about a law suit regarding some big face plates on some shower valves where someone had removed the foam. Leave it there. I always pack putty around the valve but very carefully if it is marble or granite. caulking around the face plate is always a good idea and is required by code in many areas.
            Use the putty for the penetration and caulk for the sanitary seal of the plate.
              Thanks for comment guys, I guess it was worth asking about.
                We heard about that same lawsuit
                I love my plumber
                "My Hero"
                Welcome, Phoebe Jacqueline!
                  No We didn't
                    No We didn't
                    We=Rick and I. Not we=all of us!
                    I love my plumber
                    "My Hero"
                      That was the lawsuit after the McDonalds coffe burn. I think the verdict was 2.5 million...and a new escutcheon. Or was it the dry cleaning one?
