chain wrench
  • chain wrench
    our company services gas stations, and as such we frequently have to spin a 4" riser out of a sump. Ridgid used to make a chain wrench, or chain vise that attached to the riser and a piece of 2" x 5' square stock went over a square tab on the vise and stuck out of the ground so we could put a pair of 36" wrenches. anybody know where we can get one of these. originally i believe the wrench was sold with a 6' two sided handle with a ratcheting piece in the middle for two men to use.
    thanks
    ron
    Ron,
    That was the UST Wrench (cat #56807) and you are correct, we don't make it anymore. I just did a quick Google and didn't find anything, but you might check eBay, or Google on your own.
    That was quite an outfit, wasn't it. I had a particular fondness for it, because I got to do the magazine ad photo shoot. The pro was busy the day they did field trials, so knowing I'm an avid photographer, I was asked to shoot some action shots. They ended up in the national advertising campaign! I've still got a copy from one of the magazines in my portfolio.
    Sorry we couldn't help you more,
    Steve
    Steve
    www.MorrisGarage.com
      WILL A MCMANNIS WRENCH SUBSITUTE? HOW MUCH CLEARENCE IS IN THE SUMP FROM THE SIDE WALL TO PIPE. I'VE HAD TO CUT AN24'' WRENCH AND WELD A PIPE TO EXTEND IT TO THE SURFACE. YOU COULD WELD A SOCKET TO THE WRENCH ON BOTH SIDES TO TO ALLOW FOR REMOVAL AND TIGHTENING.
      P.S I DID STUMBLE ACCROSS YOUR WRENCH ON EBAY MONTHS AGO.
        http://www.ridgid.com/parts/hand/ust.pdf
        that is the ridgid parts sheet,
        but could you make one by using a bolt on chain vice, to a piece of square tubing, and or having another piece of square tubing to slip over the bolted on tube,
        drill or torch a couple of large holes on the slip on tube and then insert a fair sized pipe through the hole for a handle.
          Re: chain wrench
          thanks
          ron
          i know it's a couple of years since you posted this. but i just found one and had to buy it since i don't already have one
          joey asked what i'm going to do with it
          i guess it will be in my collection of strange tools. if i ever need to get a nipple out from inside of a cabinet, i now have the super wrench
          smorris, do you think this is of photo quality? i will post the wrench once i get it in my hands.
            Re: chain wrench
            Having done some underground gas tanks and used the udt, it was a great tool. Why doesn't Ridgid make it anymore?
            The only thing close was a chain wrench with a socket attachment I owned. Don't remember the company, but I bought it through McMaster-Carr.Check their website.
            the dog
              Re: chain wrench
              Cool find! Kinda small photo. I'll have to find my magazine ad and scan it.
              Steve
                Re: chain wrench
                Can i get a better pic of the vise?
                  Re: chain wrench
                  there is the vice, 2'' socket for the corporation stops and a hex socket adapter. the extension is a telescoping 2'' drive with the 6' wrench that ratchets. a monster of a tool.
                    Re: chain wrench
                    What is the large hex piece used for??
                    That is a different wrench for sure, never seen one.
                    G3
