Pipe Freezing (on purpose)
  • Pipe Freezing (on purpose)
    Since we have been on the subject of frozen pipes, what is your preferrred method to freeze a pipe for the pupose of pipe repair... particularly water service mains?
    spodelee
    Until lions have their own storytellers, stories of the hunt shall always glorify the hunter
    Re: Pipe Freezing (on purpose)
    I prefer Jet Swett system to freezing, but there's plenty of guys that like it.
      Are they available over 2"?
      They are not always the answer. For instance if you need to isolate a section of pipe but you don't want to cut into the line, a Jet Swett will not work for you.
      We have some systems that purposefully do not have isolation valves so that they can not be turned off accidentally or oterwise. When repairs have to be made to the equipment they service and the common header can not be shut down the only way is to freeze the line and maintain it for a few hours (maybe 8 or more) while repairs are completed.
        Excavator I do locates and camera for uses gas, I think nitrogen. Works well. Saw them repair a couple of ~2" soft copper lines they had yanked all twisty when they caught them with the hoe on the way to what they were after. Really was sweet. I can get you brand/model of what they use if you like.
          i freeze up to 2.5'' with my ridgid super freeze 2500
          up to 4'' with co2 and freeze bags.
          remember that running water will not freeze.
          trying to freeze a main takes a lot of cooperation with the rest of the users
          freezing an end of the line is easy. no flow, no problemo
            Yup, we have the RIDGID Super Freeze and also do the CO2 thing for larger lines.
              I figure you have three Super Freeze units and will soon sell me one for $500 cuzz your a nice guy!
              spodelee
                you're correct. i have 3 super freeze units 1 -2000 and 2-2500
                if i sold 1 to you, that only leaves me 1 for work and 1 to freeze my chocolate milkshake
                i'll run it by the boss
                  Specifics would be great. Always nice to know exactly what works! Thanks!
                  spodelee
                    rick,
                    i used to think that until i helped fight a fire at a estimated -127 below with the wind (it was the most fridgid day in my life, so far).
                    we were taught to leave the fire hose nozzles cracked open when not in use to prevent freezing.
                    we ended up having to cut all of the lines off (2 1/2") the truck and a front end loader had to dig the truck out of the glacier that formed around it.
                    just a thought.
                    Vince
                      They go to 4". The bigger sizes have a flow through valve which allows you to hook up a hose and bleed pressure off.
                        Thanks for the input guys. Bought a 2500 Ridgid yesterday... we'll see how she works and go from there
                        spodelee
