Old school?
  • Old school?
    I recently replaced a kitchen faucet and bedded it with good old plumber’s putty from a container purchased 25-30 years ago.
    While not a plumber, I grew with several relatives who were in the trade.
    My question: Is plumber’s putty passé? Are there better, more hi-tech products to use these days?
    ----Mike
    Re: Old school?
    Nope
      Re: Old school?
      most of the higher end faucets now come with a sealing gasket or o-ring that is used instead.
      that putty of your's was still pliable after 25-30 years
        Re: Old school?
        Not sure if this faucet was "higher-end" or not as my wife selected it and I didn't see the receipt.
        The base has a plastic gasket, but instructions indicated use plumber's putty or other "bedding material".
        Can of putty was new, unopened. "Hercules" brand. It may be even older than 25-30 years.
        Appreciate the replies guys.
        Happy Holidays
        ----Mike
          Re: Old school?
          After all these years putty still carries it's weight.
            Re: Old school?
            Thats what I was thinking , Must have has a good area that was dry, like the ocean
              Re: Old school?
              I have taken all my putty and pitched it. I am so tired of shower and sink strainers leaking in time that I use 100% siicone on all of it.Have never had a leak since...Only downfall....trying to get that strainer off a ss sink if there is a problem, you just about have to stand on it...Mark
                Re: Old school?
                The company I work for uses silicone mostly in place of Plumbers Putty. But as was said, it's a PITA to service if needed.
                  Re: Old school?
                  I never use silicone. Plumbers putty is my personal choice. Nice eagle pictures by the way.
                    Re: Old school?
                    I have never had properly installed fixture leak using putty.Please stop using silicone.It has it's place on very few occasions,I use it myself.Not on every install,especially something like a basket strainer where I have never used it.When the garbage disposer goes bad in a few years it has unnecesarily made a lot of work for the next guy.
                    Hey...Just a thought...Lets do away with pipe dope and start using silicone there too.
                      Re: Old school?
                      would not be using silicone for anything connected to potable water, some silicones can leach into the water system.
                        Re: Old school?
                        Putty vs. silicone? How bout that. Who started this? As a service plumber there is nothing worse than dealing with a strainer or, even worse, a toilet nailed down with silicone. Not good when using a flat rate system. Speaking of flat rate, I think it's much better than hourly.
                          Re: Old school?
                          So what does Plumbers putty do to natural / cultured stone anyway?
                          I had a talk with a Granite countertop installer the other day but all he could say was don 't use it but not why...
                          Some type of chemical reaction would be my guess
                          I don't use it on stone only because I was taught not to...
                          Okie
                            Re: Old school?
                            Devil Spawn!!!!
                              Re: Old school?
                              Okie
                              I've never seen it Bill.
                              I wonder if it has a discoloration like that oily rainbow reflection,similar to oil on water.
