Pex freeze easier than copper????
  • Pex freeze easier than copper????
    Last year we ran new lines for a customer's bathroom during a remodel. We took out the copper and replaced it with pex. We pretty much ran it in the same spot (same holes) as the copper.
    This will be the second time they have frozen over the past month. Granted, the windchill is around -20 to -30 degrees both times, but they said it has never happened before (of course they are going to say this, but maybe its true ???)
    This is above a garage ceiling and I do know the bathroom on the other side of the bathroom we remodeled has a cold floor. That bathroom is also above the garage.
    Is it possible that heat transfers to the copper pipes and the pipes stay warmer longer than pex? It's weird because the its the hot water line that keeps freezing and the hot and cold are ran pretty close together.
    Any thoughts?
    YourHomeContractor.com - The Trusted Online Community For Homeowners and Contractors.
    Plumbing Reviews
    Re: Pex freeze easier than copper????
    Hot water has a lower "specific heat" meaning that it takes less "energy" to change states. In laymans terms hot water freezes faster than cold water!
    With regards to why it is freezing up now more than before check for drafts or anything that may have changed. I would imagine that PEX vs. copper for insulating the PEX would do better but I have been wrong MANY MANY times in the past!
        Any thoughts?
        My house is around 12 years old and it's starting to get drafts. The same thing could be happening in that house. May have created a few drafts during the change out.
          I would try to find were the cold air is getting in to freeze the pipe..
          During the remodel {some carpenters } dont think about the plumbers pipes. during the summer its even worse..
          Why would some one want to take out copper pipe .to put in pex ?
            I would bet it isn't insulated the same.
              No. How could it freeze faster? Copper is a better conductor of heat/cold.
                Please explain in more detail, this specific heat theory?
                  I would really wonder if there was some insulating done during the remodel which may contribute to this situation?
                    Here is some UV damaged pex...its been installed on a pier with direct and indirect sunlight for about 5 years. It froze lastnight and split.
                    The only part that split is the sections of pex that were exposed to the sun...the pex under the pier was fine and so was some pex that I replaced on the same pier.
                    Gave the guys boat motor a good power washing
                      The Mpemba effect though documented and repeatable requires a very specific set of conditions to occur. Conditions that are not often found in normal circumstances. I would be looking for some place where the carpenter missed the insulation. Once frozen though, pex can be a real bear to thaw. Often times the only thing you can do is bring in the salamanders and get the house up to 100 degrees and wait.
                        Or lack of insulation. Here we are require to have a minimum of R 30 in spaces that are subject to freezing..Especially like in your situation an over the garage system
                          Forget the UV breakdown . They def. forgot about draining down that hose bib..Heck copper will do that
                            the other thing that I remember about hot water water is oxegen molicuales are less and so it will freeze quicker something like that less or more
                            SMELLS LIKE $$$$$$ TO ME
                              The pex that was protected from the sun froze but did not burst...and it froze last year too...did not burst. Only the pipe exposed to sunlight split,the rest was good.
