Need help w/ roughing
  • Need help w/ roughing
    Can someone tell me what is the correct height for the roughing for the installation of a Sloan flush-ometer.
    Thanks!
    hope this helps
    www.sloanvalve.com/installation_documents.asp
      Thanks! I will check it out.
        JohnnieBoy,
        Did it help? Sorry I couldn't do more the were just too many factors to consider.
        JJC
          If you know your toilet height (depending on whether it is a standard bowl or an ada bowl) a sloan valve is eleven and a half inches tall. From the center of the fixture to center of water stub out is four and three quarters. Tip: Make sure if you are roughing in an ada toilet, that the handle must point towards the largest opening of the stall. So, be sure to put your water stub out on the narrower side. I usually go four and a half inches to center, and ten and a half inches higher than my toilet. Remember you must have atleast six inches on your vacuum breaker.
