Drilling holes in stainless and cast iron sinks
  • Drilling holes in stainless and cast iron sinks
    OK, I'm being a little bit lazy here, but if someone could help me out, I'd appreciate it.
    I need new bits for drilling faucet holes in stainless steel and cast iron sinks. I used to have a really nice set, but lost it when a work truck I was using burned to the ground. I got all my other tools off the truck as it was burning, but thats a story for another day.
    What are the names of the bits I should look for? I know the cast iron bits are a three piece set, but I can't remember the name for them.
    Or can someone post the link to the old thread about this? I tried looking for it, but I didn't find it.
    Re: Drilling holes in stainless and cast iron sinks
    relton makes the bits. a carbide pilot hole is first. the porcelan cutter is the most critical.
    the cast iron cutter cuts inside of the score line. i always use a small magnet to collect the cast shavings to prevent rusting.
      Try em'
      http://www.hougen.com/cutters/sheetmetal/Rotacut.html
      You will like em'
        For Stainless sinks I use a 1-3/8" Greenlee knockout punch.
        http://www.mygreenlee.com/Products/m...db_next_page=1.
          I just use the Lennox step drill bits for SS sinks. They work like a charm, and very fast.
            Maybe this tells of my inexperience but I've never had to drill a cast iron sink nor have I removed old fixtures off of one that was drilled.
            New to me. Thanks.
              I`m with ya JC....hummmmmm
                Thanks. I might have to get one or two of those bits. I had a customer that bought one of those sinks from Lowes made of "blended materials". I don't know what it's called but it was black with little grey flecks in it. Heavier than you think.
                Anyway, I had to drill a couple of holes in it. So I grab just a regular hole saw and it did it without much problem. The second one obviously took longer than the first. When I was done...the teeth were completely gone! And the hole saw (Lenox) wasn't that old or in bad shape.
                  http://www.lenoxtools.com/enUS/Produ...LE_CUTTER.html
                  Best I've used for SS. Never had to drill in CI.
                    Any danger of overheating and discoloring the metal?
                      I just Drilled a new americast Sink used the Lenox and Light oil I consider the Hole saw expendable after That
                      Dave
                        Dave
                        Reg. old lenox drill bit ,3/4" or so?
                          Originally posted by TozziWelding View Post
                          Funny,thought of My Mag drill and annular cutters,right away. Must be a welder thing!
                            We use Relton.
                            The boss requires a signed waiver of liability before we drill.
                            That way we don't buy a sink, that the customer could have bought and saved the drilling.
                              The SS is easy to drill, cast(thin like sinks and tubs) likes to crack.
