dry fire sprinkler
  • #46
    Re: dry fire sprinkler
    Just for anyone interested.
    http://www.uponor-usa.com/Misc/Appli...eneral-FS.aspx
    • #47
      Ive worked in 1 house that had a sprinkler system in it. The homeowner was also a sprinkler system company owner. It had the orange pipe. I didnt pay attention, but if you guys say its CPVC I'll believe you. I do remember it having its own 2" water service from the street.
      Theres a dry system at my shop. It functions as Bob mentioned with an air compressor to keep 70 or so pounds of air on the top side of the clappers. If a head opens up the air pressure will drop, and the water pressure will overcome the clappers filling the system and sending water to the open head. Theres 6 of these clapper valves with 6" lines supplying each one. Its an impressive system that serves a total of 140,000 square feet.
      Andy
      • #48
        Well there is not much that is not flamable if you get it hot enough!!
        The flash point is around 200* F and is very stable. It is used for de-icing planes, making smoke, and used extensively in food and cosmetics.
        Okie I think somebody fed youa line of crap. Just my opinion.
        G3
        • #49
          What kind of a place do you work at Andy?
          G3
          looky here for the orange pipe
          http://www.blazemaster.com/default.asp
          • #50
            What's the flashpoint of water?
            Think before you answer....
            • #51
              [quote=G3sprinklers;203974]Well there is not much that is not flamable if you get it hot enough!![/quote]
              Just like I said
              G3
              • #52
                [quote=G3sprinklers;203980]
                Just like I said
                G3
                ?????? Lighten' up G3.
                • #53
                  Sorry, been a long day and still going.
                  G3
                  • #54
                    I agree the Air Force made a bad choice on that one... That was about 8 years ago when PGlycol was not as well known.
                    The residental sprinklers are comming, as always it will be a mess as the states and codes try to sort it all out
                    • #55
                      Re: Dry system or not, you need the correct backflow device
                      Originally posted by MoJourneyman View Post
                      brass sprinkler heads, in a pex line, no part of that is non-potable. Were I to use the rv antifreeze, then yes, an rpz.
                      This line, is it dedicated? Meaning, serves one purpose and one purpose only.
                      Meaning, a tee...or are you catching this off a run that serves other fixtures.
                      • #56
                        in this instance, If I install it, it'll likely end up a wet system, just to avoid the having to install a compressor, and i'll likely make it a pressure loop, with no other fixtures on it.
                        if the concern is a line where the water is never flushed out, it's no different than that upstairs hall bath in many mcmansions after the kids move out.
                        • #57
                          also, don't take statements like that from me as being standoffish, I read this forum because I learn a lot, and I should have phrased that more as a question.
