Real Plumber's Water Heater ;-)
  • Real Plumber's Water Heater ;-)
    Seems the "newer" heaters are kinda Wimpy ! They Don't seem to Put out the quantity or temperature they used to ...
    I'm talking about an old 40 gallon single element No heat traps Vs a "new" 40 gallon dual element with heat traps
    I just Installed a New 30 medium in a shed (Mh Park) they only had 110 v out there so I "re-Whhhared it ;-)" 110v 1500W single element, NOS Thermostat ... Then I called them the next day and asked " How is it " They Love it ....
    Sooo Do any of you guys "mod" your own heaters ? Longer Dip tubes 5500 Wat Elements , NOS thermostats etc ... ? (I'm talking personal use NOT for a customer)
    Dave
    Re: Real Plumber's Water Heater ;-)
    If I'm installing for myself I'll do whatever I want to get what I need from it.
    When servicing a customers I'll "improve" it if they're having an ongoing problem with original design.
    Ex: Replacing a bad diptube with a longer one. Some A.O.'s only go about half way down. I'm no engineer but that doesn't seem right.
      How's this for a water heater mod.............
        instantaneous no less
          Water heaters should work well right out of the box. If not return it and or switch brands. The only mod's I do on water heaters is replace the plastic drain valve to full port ball valve with hose adapter and brass cap. Also if flow is restricted too much I yank out the heat trap nipples and use regular brass ones. Anything beyond that is taking on liability by altering the manufactures design and voiding warranty.
