Tankless Rick....
    Re: Tankless Rick....
    I think it is Grundfos that makes a tankless recirc that has a 1 gallon tank built in.
      I also am unimpressed with the two Rannai 75i units piped in parrall I installed on a big house I did a few months ago. What a waste of money!
        Originally posted by NHMaster3015 View Post
        Hey Rick. Do me a favor and post your results over on Terry's forum under the tankless threads. There's a couple morons over there that think they are the last word.
        you're more than welcome to post a link or just quote and post my words.
        another forum, i barely have time to read all the ridgid stuff.
        this forum has exploded with new members and fresh along with repeat post it all runs in cycles
          a real circulating system requires a return line.
          something my tank system never required.
          the hybrid circ/ pump on hot outlet of heater, hot cold crossover manifold under far sink, works pretty good for tank installs. won't work on a tankless.
          so know when i want to take a shower at the far end, i turn on the 3/4'' roman tub valve to move some water and speed up the wait.
          talk about a drop in volume. the tub only fills at about 6-7 gpm on the hot and a good 14-15 on the cold.
          i'll write more as more info is gathered.
          don't be shy to anti up the $10.00 testing fee
            We did the same thing.Took place of a 100gal powervent(an extreme P.O.S.)
            Because I was not the primary plumbing contractor I never was able to follow up on their performance.Ours dumped into a hundred gallon holding tank with a recirc system.
              Whether or not it's a waste of money is not for us to say. The privilege of making that call goes to the guy/gal signing the check.
                O/K now I FINALLY understand what you are saying.
                • #23
                  I think the forum's server is mad at me.
