When changing heating elements...
  • When changing heating elements...
    Do you guys drain the water heater? Or just pull the element and let the water gurgle out? Bottom element of course.
    I have done it either way. Depending on the location of the heater. Just curious.
    Re: When changing heating elements...
    I will shut off the water of coarse, then relieve pressure, and unscrew lower element first reliying on the vacuum to hold the water back. But I have my shop vac ready in case it doesn't work or if the element is twisted back on itself and I have to hack saw the element to get it out. Draining the whole heater is my second choice.
      I turn off the water ,tape a small piece of plastic or tin foil, around the element .and make a water slide into a low cake pan...and change it quick
      no mess at all
        Have done it both ways, just depends on location.
          I usually don't drain them. I even install full port drain valves without draining it.
            aint physics great!!! bertoulli's principal IIRC
              Yupp ... Push pull Click Click .... Cha Ching :-)
