Waterless urinals
  • Waterless urinals
    Okay here we go ... Bottom line properly maintained "normal" urinal VS The costs of Replacing the Waterless Inserts ... And Environmental impact of the water from a "normal" urinal VS the Disposal Impact of the inserts ...
    Dave
    Re: Waterless urinals
    Also factor in jetting and snaking the lines at least once a year to remove the buildup the water used to carry away, and yes you may have to pull the urinal each time!
      Where do all those
      stinky mineral deposits go? I know nothing about them.
        Waterless urinals are the worst drains I have cleaned. Would it kill some one to pull the Cartridge and run a few gallons of water through it. It seems to me that not only do you have to still treat the water that the urine ends up in but you also have to dispose of the cartridges. All your saving is the gallons per flush. Probably better off with a sensor unit that flushes every hour or something like that.
          They are evil, stinking, non code compliant and a shining example of how industry whores get crap accepted.
            NH Master you are a prince. Perfect.
              All you drain guys,think of the worst urinals you have had and that job becomes a guarantee with every call to one of the stinky messes.$$$$$
              Hope your not hung over!
              I will consider special rates to take all the headaches into account for the waterless.
              Green my a $ $ .
              Do any of you have any codes regarding any gray water systems.
                are terrible. Period.
                  This is what I suggest instead...even if it flushes out each urinal 8 times a day its still much better
                  West Trail Mechanical Ltd
                  www.westtrailmechanical.ca
                    Never heard of one, how do they work?? or not work??
                    Sounds like you are just taking a leak into an open pipe, surely not!
                    G3
                      http://www.waterless.com/
                        Looks like those would be just plain nasty and smelly.
                        G3
                          G3
                          I've come across bathrooms that smell similar to a barn...seriously
                            I have not run into these yet, thankfully.
                            I dislike the regular urinals, so I imagine I will absolutely hate these.
                            The money they save on water they can spend on an extra waterless urinal charge for me.
                              No.... there is a cartridge in where the pee goes it has a chemical that floats on water to seal the Drain and keep the odor down. lol
                              http://waterless.com/index.php?optio...id=3&Itemid=55
