1" Pvc repair couplings
  • 1" Pvc repair couplings
    Anybody know why they don't make 1" pvc glue repair couplings. I sometimes drimmel out the stopper but that takes time.
    You can lose with me, but you can't win without me!.... PPI
    Re: 1" Pvc repair couplings
    Ever tried a a piece of sched 40 1 1/4"?
    West Trail Mechanical Ltd
    www.westtrailmechanical.ca
      Have you ever tried a flow span cpl ,,
      It has a oring in it and it wii extend out 3 or 4 inc's
      they make for a good repair without the fight
      Are water presure is between 50 to 55 psi ,never had a problem with it
        1 " Pvc Repair Coupling
        Model # QF-1000 by KBI/King Brothers
        $4.69
        In Stock - Estimate Delivery Date
        Made of high-impact PVC Type II material in 1-piece cylinder to avoid leaks - no solvent weld necessary. Internal, high-quality, self-lubricating EDPM o-ring for long life and smooth movement. 150-psi pressure rated in all positions. Complies with all applicable ASTM and ANSI standards, NSF Approved. This 1 Pvc Repair Coupling is one of many top quality items in our Compression Couplings department.
        Aubuchon Item # 641789
        Other Related Departments: Compression Couplings
        KBI/King Brothers Compression Couplings
        KBI/King Brothers
        Probably to sell more of these!!!
          I have found that those telescopic repair fittings to be somewhat unreliable. We have used them around the school district for irrigation and service line repair and they have a tendency to break later on their own. Even with a good compacted bed of dirt! I prefer the 4 90 trick when in a tight place.
            I believe someone does make a repair PVC glue coupling, but I would not use it. PVC connections need to be tapered ID, what they call "interference fit". This is so the melted plastic of both pieces is forced together. Without that tight fit, what is holding a slide-on piece in place? You need the o-ring types;
              I have used the KBI telescopic repair couplings (also for a school district) up to 4" and I have never had a failure. You do have to be careful to install them per manufacturer's instructions.
                I have seen the telescope ones but they just look bad i don't think i would trust it under the ground. I think they are made for iragation not plumbing.
                  I just use my trusty "socket saver" bit. They are available in every size from 1/2" thru 4" and work on Schedule 40 PVC and ABS. It works great with my cordless drill, simply reams out the stop. Mine are Plum Best brand, DON'T BUY Raptor brand, they don't cut right.
