Backflow prevention
    Re: Backflow prevention
    I use the same test rig wether it be for fire or domestic services, do you really think that that would introduce anykind of pathogens or bacteria into a water supply?
      Read
      http://abpa.org/bb/viewtopic.php?t=9...eparate+gauges
        Thanks Bob, that was interesting. It is as I thought, gray water for irrigation systems. We don't deal with that here in the mid-south. I do have some customers who have disconnected from the city water supply and pump their water from a nearby lake for irrigation purposes. In such cases we remove the r.p. and cap off the incoming city supply.
          You might want to check what your local regulations are before you purchase a test kit. Different authorities want different services. I know that California purveyors will only accept a test performed with a two valve gauge. Here in British Columbia they will throw out the test report if I perform a test with a two valve. I need a three or five valve gauge.
          I tend to like a dial that has BIG text and hash marks. Conbraco gauges are made by Mid-West and are more expensive than Mid-West. $740 for a Mid-West gauge compared to the exact same gauge with a Conbraco name on it for $1010
          A lot of Schools have Watts gauges because Watts donates tons of equipment to schools. Try a couple of different brands out if you can while you're in the class and see what feels good in your hands. Some gauges have quarter turn ball valves for the high/low side so that you can readily see if the valve is open or not.
          Mid-West kits and accessories
          http://www.backflowtestkits.com/accessories.html
          These sites have a choice of brands and accessories
          http://www.gageitinc.com/index.htm
          If you ever have a problem with anything backflow related, Bavco can get it to you in side of 48 hours.
          www.bavco.com
            I carry 2 midwest model 845-3 testers. They are good units. You really don't have to get too fancy on the tester.I actually prefer the 3 valve. You only have to hang on to 1 bleeder hose.
            $100 per year each for calibration.
