3" or 4" lateral
  • 3" or 4" lateral
    I've got an architect who has specified a 4" waste line with a run of 160' from a guest house that serves a wc, shower, lavy and sink. I plan to suggest a 3" line because I'm worried about line carry of waste in a situation with a 1.3GPF wc, few other water sources scouring the line and intermittent overall water usage due to the sporadic occupation of the building. What do you think?
    Re: 3" or 4" lateral
    If you got the fall for quarter per foot
    push it for the best interest of the customer that you care about.
      One other thing.
      Sure would be a bummer if someone were to try and improve and they needed 4" back there and all they had was 3" under the $200,000 back patio.
        Even with 3" I'd welcome a wc or two more and/or a few more grey water producing fixtures. Better scour. However, Adam, they don't have any more room to add square footage, on that side of the lot.
          That's my plan exactly. I'm not trying to save any money. On the contrary, I'm just trying to give them the best possible job.
            Just tell them to shower after using the toilet.
              Leave an exterior cleanout. Preferably a second cleanout at the bottom of the run arranged so it can be cleaned up from the bottom. 160' and one bath that thing is going to plug one day regardless.
                I don't think saying that will endear me to the architect. On the brighter side, I don't think with the present layout that any tree roots will have a chance at attacking my line.
                  He'll put one in every 100' as well as within 2' of the structure,cause he knows his code.Maybe even one at the tie in if he decides to bring the test wye to grade.
                    Will the inspector go for a 3"? Are You sure!
                    Why would a plumber ever let an Arch. design His system?
                      Happens more times than not in many cases Toolman
                        " Now how in the world am I gonna get this vented?"
                          Go give someone a pink belly
                            bigger is not always better.
                            definitely 3''. the 4'' will not self clean as well. you still have plenty of dfu to add a laundry and another full bath and kitchen.
                            all will eventually plug if it's just a toilet and lav.
                            i have 2 large condo buildings i take care of that had powder rooms/ toilet sink, separated by over 60' from the rest of the waste system. the piping is exposed in the garage ceiling. fall is perfect, pipe is new no hub camered line and the line is spotless.
                            a powder room only does not generate enough grey water discharge to help push out the paper and #2.
                            a shower, tub, laundry is what helps with washing the waste to city main.
                            1.6 is low, 1.28 is crazy
                              Per 2007 CPC (UPC) Table 7-5, up to 3 wcs are allowed on a 3"' vertical line w/unlimited length
                              Btw Tool, Table 7-5 applies in Marin just like it does in San Mateo.
                              It doesn't show up on the architectural drawings. But, because it was assumed that it would be running exterior to the buildings for a majority of it's
                              distance, it shows up on the civil drawings (labled 4"), which were drawn by civil (non plumbing) engineer. I think that's why the architect is nervous. He may suffering from engineeritis.
