Looking for a new torch
  • Looking for a new torch
    Anybody use one of these?
    http://www.supplierofchoice.com/industrial1.htm
    I have a buddy that swears by this torch. I haven't used it, but since I'm in the market for a double barrel, I figured that I'd give it a shot and be the first on my block with one. I'm sure they've been around for some time. Opinions?
    Re: Looking for a new torch
    Never used one personally, I would opt for the acetylene with a assortment of heads personally. Out of curiosity, why would a person need a double barrel?
      Since I have to buy my own feul I very,very rarely use mine.I have a b-tank to silver solder or soft solder the larger fittings.
      The self ignitors get in the way of maneuvering around a fitting to get a uniform joint temperature without frying everything in the vicinity.
        Easy to get around the project.
        I was using one when I was running some 1-1/2"&2" for another company a few years back.
          Why double barrel
          There are quite a few houses here with 1.25 and a few 1.50 copper coming into the house. The double just covers more ground.
            Speaking of torches...
            Have they ever made a torch with swivel out tips so you can heat both sides of the joint at once? I couldn't find one on the web, but have always thought it would be a nice tool.
              Re: Why double barrel
              I am thinking if you need this your left your b-tank at the last gig!
                I like the Turbo Torch TX500. I'm not a big fan of the swivel type torch as it is harder to get into tighter spaces.
                ________
                Arthur chevrolet history
                Mike
                  This is my torch of choice, with mapp gas.
                    NHM,
                    I had no idea how well off you were.
                    You must be the envy of many an aristocrat at the mens club with that cigar lighter.
                      I use this the majority of the time.
                      Even though some turn their nose to them, I had a Bernzomatic one time that worked as well & lasted as long as the other TurboTorch I had.
                        For anything up to about 1 1/4 it puts out plenty of heat and is a hell of a lot easier to hoof around the job site. I have the full size turbo in the van also but I'll bet it hasn't seen the light of day in a year. With mapp gas, it gets damn hot.
                          NHM,
                          Wish I could write like that! Just how many pink bellys can You handle?
                            Have one and I like it . Won't silver solder though.
                              Quite a few due to the fact I've built up a tolerance.
