underground natural gas leak
  • underground natural gas leak
    I am at a rural school facility chasing a d##n gas leak.This stuff has been added to, taken from, and modified by every country wanabe in a 20 mile radius. Question is , how are yall finding underground leaks????I have tried and tried to get the school to repipe, but no no no, they tend to think they are getting out cheaper by just fixing what is there. Only thing is, after a week of hit and miss, we are still not finished.guys any info would be helpful, before I go postal and shoot everyone involed. some days your the windshield, some days your the bug.....
    Re: underground natural gas leak
    Get the gas co. to come use there gas sniffer. I believe Ridgid makes one if you wanted to buy one. Keep trying to get them to re route the lines. Explain how dangerous this could end up. Gas is nothing to play around with. Let parents find out, then see if they fix it right. Good luck!
      if it is grassed the grass may be discolored or dead where it is leaking,
      pictures on the below sites,
      http://rentalrealproperty.com/wordpress/?p=57
      http://www.cityofdunlap.com/gas%20pu...areness%20.htm
        When we have one main that feeds several structures, the first thing we do is install ball valves to isolate everything and to test the buildings. If you have leaks in the ground, your just chasing your tail, to properly test your work you will continue to find the weakest areas and a week after you think you fixed it you will be back. It's time for a new line.
          Yea had to do this at a factory once. Its easiest to get the gas co. to bring a gas sniffer.
            Get the gas company involved. If that doesn't work, call your local gas inspector. If all else fails, drop a dime to a news paper.
              had a school gas leak job like that ,the gas co put a little extra stink in the pipe to see if we could smell it out...
              6 weeks later i had the under ground pipes changed out
              some jobs never end
                had a gas leak so bad at a high end condo that we couldn't get it to hold air while filling with an air bottle. then tried 2 portable air compressors. only went to 5 psi.
                finally a 160cfm tow-able compressor. figured we could hear it sounding like a sand blaster. nothing. gas co. told us it was inside. heard nothing.
                went outside and watered down the 40' area between the meter and where it entered the building. the ground was bubbling all over the place.
                found out that all 11 as lines that were installed just 6 years earlier were not factory wrapped. all the lines were rotted, but at 7'' w.c. it didn't show up until the gas co. had shut the unit off and went to clock test the meter. the line was 3' deep and buried under landscaping that looked like a park. even had to pull 2 mature palm trees.
                original plumbing contractor was already out of business. the original gc contractor picked up the tab. don't know how the city ever signed off on this project as they are typically very hard nosed.
                even if you find the leak, it's usually not very feasible to re-thread a section of buried gas pipe. i guess you need to see it's general condition.
                now if you really want to locate it. have a co. do a helium test. the helium is such a small molecule that it will escape out of the smallest hole and then can be sniffed with a helium sniffer.
                or you can just walk around till you find funny talking people
                  Thanks yall. Rick i never heard of the helium trick.yall were thinking the same way i am. Funny how great minds think alike!!!!:d
                    Except for the ones running the place who are not able to see the savings of replacing the line completely.
                      Drop a dime to the PTA president about unsafe conditions at the school! Guaranteed results. Hell hath no fury like a soccer mom on a mission!
                        went outside and watered down the 40' area between the meter and where it entered the building. the ground was bubbling all over the place.rick.
                        Priceless!
                          Has'nt the gas company locked down the meter yet. The do that first thing when there is a leak here. That is the quickest way to get the ball rolling. No heat no food no hot water. The school closed.
                            YES THE GAS CO. HAS LOCKED DOWN THE METER.EVERY YEAR IN TX SCHOOLS HAVE TO HAVE AN ANNUAL GAS TEST. THE SCHOOL HAS HAD ONE FOR YRS, BUT THE FUNNY THING IS NONE OF THE SCHOOL OFFICALS HAVE EVERY SEEN ANYONE PUT A GUAGE ON THE CUSTOMER SIDE OF THE METER. THE LAST GUY NEVER DID THAT. COME TO FIND OUT, THIS YAHOO DIDN'T PRESSURE TEST ANYTHING, HE JUST WALKED AROUND THE HALLS INSIDE THE SCHOOL WITH A "SNIFFER" THIS JACKASS WASNT EVEN A LICENSED PLUMBER.THIS IS THE LARGEST REASON I HATE WORKING IN UNICORPORATED AREAS. IF TRIED TO PULL SOMETHING LIKE THIS THEY WOULD PUT MY A$$UNDER THE JAILHOUSE. AGAIN THANKS, ITS NICE TO HAVE PEOPLE LIKE MINDED TO BOUCE IDEAS OFF OF,AND VENT TO!!!!
                              You'd think in TX they would be the world leader in gas safety with the history of NG there.
