Sf amendmendt.
    Re: Sf amendmendt.
    Originally posted by Service Guy View Post
    Yep, I didn't know what they were talking about either. I use long sweeps for virtually everything. I try to go ABOVE code on my repipes anyway, not just get by with the minimum. It makes passing inspections easy, because I know all my vents and drains are piped well above minimum code requirements. I pipe drains from a service guy's perspective, trying to make everything drain perfect and be easy to snake out in the future.
    I hate some of the new construction plumbing I see...hardly any cleanouts, and double san. tees on lavs, back to back toilets...they don't care about quality, and they make future drain-cleaning a b!tch.
    I like how our code lets us use vent 90's after we tie in the basement vents and offset into the crawlspace with the same.It's above flood rim.
    Why would a fitting under a crawlspace get more priority over one buried in drywall,tile,stucco or siding.
    I add even more cleanouts since joining the forum.No double san-tees.I thought they were illegal.
      Re: Sf amendmendt.
      Why use a vent 90 EVER? That is my question.
        Re: Sf amendmendt.
        THANK YOU!!!
        They are legal here. I HATES THEM!
          Re: Sf amendmendt.
          Sometimes the building structure is less affected by using one. Sometimes.
            Re: Sf amendmendt.
            vent 90's are only legal 6'' above the flood level of the fixture.
            sanitary fittings are used when the vent is less than a 45 from vertical.
            Inspector " fitting would be legal in wood frame ,is not in concrete, S.F. amendment to U.P.C."
              Re: Sf amendmendt.
              Also, there is the commonly known Vent Ell, 90, & L.S. 90.
              The Vent Ell being the tightest legal vent fitting. I have not used one in years.
                Re: Sf amendmendt.
                Are you thinking of plastic or cast?
                You can snake through cast.
                And plastic can get you out of some pretty tight spots without hacking up the framer's good work.
                • #23
                  Re: Sf amendmendt.
                  I thought it was less than forty five from the horizontal.
                  • #24
                    Re: Sf amendmendt.
                    I'm crosseyed and confused on venting again.
                    • #25
                      Re: Sf amendmendt.
                      A LONG SWEEP IN C.I. IS LOOONG. Inspectors let us use mediums ,in their place.
                      • #26
                        Re: Sf amendmendt.
                        I never used one...ever. I have seen them before. I didn't think they were legal. My first boss never used them and I picked up his habits.
                        • #27
                          Re: Sf amendmendt.
                          Plastic. They look almost like pressure 90s to me.
                          • #28
                            Re: Sf amendmendt.
                            We have to get You out of NUNA . Kinda like the Bermuda triangle
                            • #29
                              Re: Sf amendmendt.
                              Yeah, you go in a crawlspace, open a can of glue, then lose track of time & what happened.
                              • #30
                                Re: Sf amendmendt.
                                Have you been following me around? I'll be in a crawlspace sniffing pvc cement tomorrow morning.
