Water Jetters
  • Water Jetters
    Hello all,
    I need some advise on jetters, we have a 4gpm 3500 psi Jetter with 16 hp engine. It works great for clearing a drain fast but does not cut roots, we recently bought a cutter head for our jetter but we do not have the volume of water needed to run it. I am thinking about getting a truck mounted jetter or I have seen a tool box mounted jetter at a trade show. What are others using? What do like? and what do you recommend?
    Thanks
    Re: Water Jetters
    4gpm @3500 psi is pretty much the specs for the ridgid root ranger.
    we've seen the root ranger is action at the roundup last year. for 4'' and larger it's the bomb
    the rearward facing 0 degree impact with a 15 degree oscillation will pull its self in and cut anything on the back of the jet.
    there are a few here that own them.
    i don't, but would like 1
