Pipe tweaking
  • Pipe tweaking
    Do you ever warm up your pvc pipe to take the stress out?
    We tapped into a manhole to repair a bad tap {no camera involved} A 16th bend was almost perfect,,but it had some stress on the pipe,a slow warm up and bend let it relax to a great fit it was slight bend but it really helped
    Re: Pipe tweaking
    How did you heat it? Heat gun?
      Re: Pipe tweaking
      I just hold my turbo torch back a little and rotate the pipe..It is easy on small sch 40 water lines
        Re: Pipe tweaking
        Interesting. I've never seen that done before.
        I wonder though if heating PVC enough to make it pliable will weaken it?
          Re: Pipe tweaking
          theres an inspector here who teaches alot of cont. ed classes and his biggest pet peve is bending pipe he always says pipes are not fittings! i think it looks good though
          Mike
          www.plumbinginclarkcounty.com
            Re: Pipe tweaking
            I have a Greenlee blanket that does up to 1 1/2". I like it.
              Re: Pipe tweaking
              i came back to my work station one day and found two electrical apprentices using my turbo and tri stand to tweak pvc conduit
                Re: Pipe tweaking
                I've used a weed burner to heat up 6" (For a pop sleeve).
                  Re: Pipe tweaking
                  Ever try threading it? Works great on urinal drains.
                    Re: Pipe tweaking
                    WHEW for a minute there I thought you guys had gone over to the dark side and talking about crack
                    I think it looks OK. Might keep it from cracking in the future.
                    G3
                      Re: Pipe tweaking
                      No stress or pressure on the conection is what i am after
                        Re: Pipe tweaking
                        yeah sched 80 only
                        West Trail Mechanical Ltd
                        www.westtrailmechanical.ca
                          Re: Pipe tweaking
                          Done it, works fine. Dan doesn't inspect My Elec. , Wong does
                            Re: Pipe tweaking
                            Gettin the He$$ outa there is nice too!
                              Re: Pipe tweaking
                              wayne wong..? the plumbing inspector
