Plumber's Grease, and Vaseline
  • Plumber's Grease, and Vaseline
    http://www.gacintl.com/msds/FluxVaseline.pdf
    http://www.herchem.com/msds/MSDS39plumbers-grease.pdf
    Tell me why I shouldn't use vaseline.
    BTW, the vaseline is for anything non-rubber, like threads on anything not in contact with potable water.
    Re: Plumber's Grease, and Vaseline
    Just make sure you don't mix them up !
      If you have ever used one on a condom......that is experiment number 1.
      (If you have not....Nine months to get things square if you do!)
        Too late! Just got back from the hospital, got myself on a 24 hour ban from lookin' at the ladies!
          Re: Plumber's Grease, and Vaseline on a Sat. nite !#$%
          Suggest You clean those bib overhalls before the big ho down! OH AND
          STEP AWAY FROM THE SHORT CAKE
            Vaseline is petroleum based and breaks down rubber products.
              vaseline is petroleum based and breaks down rubber products.
              we warned him , ouch
                Yep, got that, and I have the food grade silicone grease that
                is FDA approved for potable applications.
                I need to come up with a cheaper alternative for the grease for threads like on anything that's going to be like a set screw for a handle, the bonnet nut on a Delta R10000, screws that hold a sewer cleanout cover or shower drain.
                That medium yellow grease is getting expensive for me by the tube since I'm always using this stuff, and I can manage this idea completely cheaper with the vaseline idea. Twice I've used that vaseline, a small amount on the threads of an aerator. Just enough to make sure it can break loose down the road.
                I wish I could find a cheaper alternative for the food grade silicone based grease because I'm literally getting ripped off for those little containers and how much they are.
                Doesn't anyone use this stuff as much as me? Everything I touch...if it has a thread pattern to it or is something I've busted knuckles over, cut hands to break loose because there wasn't any on it, I'm making sure by old school design that it will have grease on it, no matter if I'm coming back or not.
                Someone will thank me on that time and day when it has to be worked on, that's a fact.
                  I just did a google search on "food grade silicone based grease" and came up with 178,000 hits.
                  http://www.clearcoproducts.com/food_grade.html I haven't dealt with these people before, but they do have 5 gallon pails and 55 gal drums. Should last a week or two.
                  Mick
                    I use gobs of it, but it comes with the backflow preventer rebuild kits.
                    Mick
                      Why not use teflon paste for your application? Oatey's great white is compatible with pvc and cpvc and doesn't harden up. Or use wax ring. Rick uses them on CO plugs and I use them on my broadhead thread(archery) because the wax prevents the steel broadhead from locking into the the alumminum ferrule insert.
                        a $1. bowl wax ring goes a long way on c/o threads and screws. and since it's in a plastic wrapper it doesn't require a brush.
                        use it for just about everything except faucet stem and o-rings.
                          It puts too much resistance on the components you put together, the grease is thinner.
                          Plus, that white stuff is messier than hell. I do however use it on coarse threads in plumbing, dielectrics, gas lines.
                          I'll check that out fireguy, thanks.
                            ben, you and me on the same wave length at the same time
                              Y'know, that idea would work well, and never thought about it till now.
                              I used to have hyperdermic needles and used them to inject grease in spots I couldn't get my fingers to, but that was very time consuming to load them. Of course, I pulled the needles out of them and just used the the injection tube.
