step drills
  • step drills
    I started reaming [ de-burring ] copper pipe ,with step drills. Does a great job,and fast.
    Re: step drills
    Every plumber I ran into out in the field doing copper piece work was given this tip. I made a lot of freinds off this one.
    They have bits now where you can go from 1/2 to 1-1/4.
    It really matters if you are set up to do copper for an extended period of time.If you are just doing a few pieces it doesn't justify dragging out the cordless drill.
      Re: step drills
      Thank's Adam ,It really helps Me. Every trick helps.
        Re: step drills
        tool, how about using propress
        16 oz. medium rare is perfect
          Re: step drills
          Great Idea, Why not send one of Yours North, friend?
