Manometers
  • Manometers
    I have an Omega digital monometer, but thinking of changing to a better one. What do you recommend? I use mine testing gas pressure on tankless water heaters.
    Re: Manometers
    Yellow jacket water u-tube manometer :-)
    Is cheap, tuff and requires no batteries or more importantly no annual calibration
    Okie
      Re: Manometers
      truthfully a basic "u-tube" with colored water is as accurate as it gets.
      pretty cheap and easy to calibrate too.
      the one gauge i have is pretty temperamental as it seems to be sticky.
        Re: Manometers
        okie, good minds think alike
          Re: Manometers
          Sick minds think alike
            Re: Manometers
            How do you store a liquid filled manometer? Will the liquid freeze?
            Better yet how do you read a liquid manometer?
              Re: Manometers
              http:/viot.us/hvac/shoppingcart.php $45.95 35' W C ?????
                Re: Manometers
                http://www.dwyer-inst.com/Products/T...CategoryID=296
                I use the series 1227 filled with oil and freezing is not an issue. The scale slides along the tube and u line up the meniscus with zero to callibrate and then read your pressure where the bottom of the meniscus lines up when you are checking pressure or vaccuum.
                Where I went to school use of a u-tube manometer was part of first year gas training.
                Instructions are included when you purchase from dwyer and replacement oil is also available.
                There are different u-tube manometers available depending on wether you will use oil or water due to the different specific gravity of water versus oil.
                Hope this helps.
                  Re: Manometers
                  Dwyer makes some nice stuff and well respected in the trade.
                  Nothing wrong with using one of them. As has been said simple,
                  accurate, and little maintenance. And no cal required for U-Tubes.
                    Re: Manometers
                    i use the Slack TubeĀ® Manometer/Gas Pressure Kit and it came with a 1 - 3/4 oz. Bottle Fluorescein green color concentrate with wetting agent.
                    i dont think it freezes , it never did for me and it wont evaporate
