15 1/2" toilet rough
  • 15 1/2" toilet rough
    Replacing a ton of C.I. ON THIS 2 STORY HOME. PULLED ANCIENT TOILET to find this rough.
    New closet bend in toilet gets re set. Thought 14" was the old standard. home built 1933 or so. original ,I'm guessing.
    Re: 15 1/2" toilet rough
    Was there originally tile or some other wainscoting on the back wall?
      How do you know this? Spot on!
        tool perfect measurement.
        a toilet requires a 30'' compartment min. so turn the toilet 90 degrees and you're spot on.
        i'm up to 6 steaks now
          That is too funny . I hope to up sell to a toto carlyle with uni fit adapter.
          Problem is bath has old classic tile ,and water needs to be 7" to left of center.I have 6"
          I'm guessing.
            Originally posted by toolaholic View Post
            I hope to up sell to a toto carlyle with uni fit adapter. Problem is bath has old classic tile ,and water needs to be 7" to left of center.I have 6" I'm guessing.
            This might work. Especially if you're more than 14" off the finished wall.
            http://www.dahlvalve.com/products/toto_toilet_kit.aspx
              Re: 15 1/2" toilet rough problem solved !
              Picked up a toto Aquia 2 today. Cut tile and set new closet flange for 12" rough.
