Drilling a cast iron enameled sink
  • #31
    Re: Drilling a cast iron enameled sink
    Sounds like you have a bunch of sissy lala's out there or you don't like what you're being quoted.
    If you're buying local the store should have a referral, if web purchase reconsider and buy local and get it installed.
    You haven't provided info as far as type of filter or hole size needed.
    If you're handy and have a 1/2" drill already just buy the Relton setup and go for it.
    If a 1/2" hole is all thats needed its a done deal, 1 1/4" go for it anyway, Plumber Rick gave a good tutorial.
    wookie
    • #32
      This is the product that I bought from Costco.com Would have bought local if I knew about this issue ahead of time.
      http://www.costco.com/Browse/Product...rodid=11487220
      Seems to need a 1/2" hole from what I can tell
      http://www.costco.com/images/content...pdf/443365.pdf
      I am not comfortable doing this as I am an amateur...but I cannot believe that I cannot find someone to do it that is professional. What kind of craftsman might do this? Plumber? or??
      • #33
        mike, i couldn't open the installation guide, but it's probably a 7/16''- 1/2'' hole. fortunately you have a larger area that gets covered and a little chipping should hide ok.
        try buying an "artu" carbide multipurpose drill bit.
        these should be available online or at a decent hardware store.
        post a photo of your sink and mark the spot with a coin or felt tip so i can see the condition you have.
        • #34
          Contact the manufactor Watts Premier, they usually have a referral list of installers and service companies.
          wookie
