Is the urinal my problem?
  • Is the urinal my problem?
    I was called to one of the condos that I do work at, they had a problem with the men's rook urinal. When I flush it I get bubbles out of the waste and then the water flushes slowly...but not 100% complete. I snaked the vent line and went about 30 ft past the urinal. The flush hasn't improved. I noticed that it was installed with an 1-1/4" flushometer tailpiece. Is this an older style design? The urinal is at least 30 years old and it's waste/trap is on one side instead of the middle. When I pulled the urinal off of the wall it had no visible deposits inside and the jets look clear also.
    Re: Is the urinal my problem?
    What happens when you pour a bucket of water in it?
      Calcium buildup?
        I had a similar situation recently.
        It ended up being a slice of lime from someones drink. I got it out by running a 1/4 inch cable from behind the urinal.
        Cable would not go in from the front, and I could not get a good seal with the plunger.
        Damage waiver was signed before running cable.
        It may not be getting enough water from the valve, but I don't think the size of the tailpiece would be of concern. It probably worked for the other 29 years it was in service.
          urinakeen.
