Mech. room area drain
  • Mech. room area drain
    New furnace condensate and T.P. DUMP 6" ABOVE inside area drain . S.F. signed off ,no problem. Who says outside?
    Re: Mech. room area drain
    Condensate is ok to dump into an approved receptor per 801.6 and 807.0 of the 2007 CPC. However, if it's acidic it has to be neutralized. Relief valve may discharge at "approved locations" other then outside the building per 608.5.
      some townships by me do not allow us to put condensate water into a drain ,it has to go out side or into storm water and floor drains that do not tie into sanitary drains .
        The new 2009 IPC code says the T&P can discharge on the floor.
          And they want us to drop UPC and unify under IPC.I guess it will make our job out hear even easier.
            It passes through the filter first.
              In S.F. sewer and street drains tied togeather.
