Building a propane fire pit
  • Building a propane fire pit
    I'm landscaping my backyard and adding a propane fire pit with lava rock. I have hooked up Natural gas pits up for people with no problems. I heard propane setups are different. My question is do I have to have some kind of air to gas mixing chamber or can i just screw the fire ring burner on the steel pipe and call it good?
    Re: Building a propane fire pit
    I have put in Lp logs in the past,,And it had a two part orfice that would let air inject at the burner plate
      Don't forget about a regulator(if needed) and a gas cock.
      Proud To Be Union!!
        plumb,
        for the sake of safety i'm going to suggest hiring a gasfitter.
        the last thing i want to hear is that you got badly burnt, or worse. touch wood.
        Vince
          Looking for a used 500 gal propane tank. both ends make 2 nice fire pits. Add legs,
          grills ,plasma cut flute men below rim and I'm cooking
            Originally posted by Vince the Plumber View Post
            plumb,
            Vince
            Thanks for your concern, Vince. In California, I'm a licensed plumbing contractor and I I know enough to be dangerous. In my research on propane fire pits the burner ring can soot up fast if an air to gas mixing chamber is not installed before the burner. I will experiment with this and see how it goes.
              Agreed No need to blow up someone or something. we all know that Propane is HEAVER gas than air And that install in a pit must be thought through with much care !
                  how are yougoing to cut the tank heads off safely??(without blowing up)I am curious , I have an old tank, and am thinking about doing the same thing.
                    I hope to not see this:
