Pouring a lead joint under water
  • Pouring a lead joint under water
    Ok Deadmen tell us how It's done ! Just found it on the net,I'll never tell
    Re: Pouring a lead joint under water
    lead wool.
    where is a joint under water?
    i can see a joint with water flowing. just pack it with okum.
      Re: Pouring a lead joint 3/4s under water
      Bell and spigot in trenches,years ago. Actually article talked 3/4s under water.
      I'll try to forward it tonight. I'm sure N.H. Master knows the method
        This is a fun read, must be DUNBARS BROTHER , He can write
        http://www.masterplumbers.com/fotums...t.asp?tid=8000
        Can someone help with the URL ? Me dumb
        Hint, cutting oil
          Per Sylvan Tieger;
          1- Pack in the oakum as normal
          2- place the joint runner over the hub
          3- pour in some oil and allow some to escape from the bottom of the
          runner (asbestos rope)
          4- Slowly pour in the molten lead and as you hear the HISSING from the lead
          coming out of the bottom of the runner push the runner closer to the hub
          to stop the lead from leaking out of the bottom still pouring until you
          see the entire runner filled to capacity
          5- Wait a few minutes remove the runner and feel around and you should have
          a perfect joint
          WEAR long sleeves and safety goggles etc
          NOTE the Entire hub cannot be under water just about 80%
            Consider the source.
              Granted, Sylvan's not everyone's cup of tea.
                That is the method indeed, but what they don't tell you is how to set the damn thing after you have it poured. Most times you can't get an iron on the bottom side and if you do, every time you give it a wack with the hammer it sprays water and muck all over the place. God I miss the old days.
                  I think if I ran into this situation, I would either dig a hole around it and bail out the water or wait for sun. When lead hits water that flashes to steam, you're likely to get the lead right back in your face.
                    Ni99
                      Originally posted by TozziWelding View Post
                      Ni99
                      Ya, sure, You're gonna make a pass with Ni rod under water. Bet a bushel of little necks,
                      it ain't gonna happen! I'll be over Buttermilk Bay diggin
                        I did a hydroseeder pump while it was pissin' water with Nirod, guy is still usin' it I live 8 mins from the bay off Bourne road, I will be out at slack tide slingin' eels for stripers.
                          I am not gonna do it, call a plumber LOL.
                            Be using a Gibbs lure/ Say Hi to bruce and The Chief [ stan,Eagle,maybe pigeon] He ,He
                            Small world
                              And if the hissing gets a little too loud hope that your running faster than the lead comoing at your face .
                              Steve in the trade since 73 doing new residential/Commercial work
