Does a pot of water boil faster with the lid on?
    Re: Does a pot of water boil faster with the lid on?
    Don't forget to add to the equation the delay factor when you watch the pot of water boil. It increases the boiling time to infinity.
      Now throw in another curve. Does water boil faster if salt (sodium chloride) is added? If so, why?
        Originally posted by wrench spinner View Post
        My mind was working backwards, I would then default to eEasyEman's observation regarding reflection of heat/insulation provided by the top
        I like the insulation idea too. It just makes sense. The water will heat the air above it, the larger the delta, the faster it will heat that air. If you have no lid, the hot air will just dissipate due to convection; but the lid will keep it there longer reducing the delta so that less heat from the water will be lost to the air.
          My guess is that it takes longer; because it will boil hotter so there is more heat needed to get it there.
          The web seems not to agree one way or the other. The salt might reduce the specific heat of the water, so it would actually need less heat to boil.
            Where's Bill Nye when you need him?
              Originally posted by Some Day Plumbing View Post
              So Vince why don't you do the experiment and you could inform us of the time difference.
              Simon
              i would but my power has been cut-off.
              up here they don't cut you right off. they limit your power to 15 amps so the stove and dryer are not functioning at this time.
              they limit us to 15 amps so we still have power for the furnace and fridge.
              yes i have been going through my own economic hardship for quite some time now but i am slowly getting back on top, again.
              this is all thanks to that bloody government guy that issues the work orders for the company i'm working for at the moment. his personal issue with me has cut me real deep and in fact i'm looking into sueing him.
              i've invited him to the forum but he doesn't have the gonads to show himself.
              Vince
              Tammy and i use a small tank to make hot water because the HWH/HWT is on a 20 amp breaker.
                [QUOTE=Vince the Plumber;223905]
                Vince sorry about your power problem, I'll do the experiment tonight for you after work and post the results.
                Simon
                • #23
                  [quote=Some Day Plumbing;223929]
                  Simon
                  it can always be worse. i could have no power at all.
                  i am thankful.
                  Vince
                  i'm not a holy roller, but i do believe the big guy looks out for me.
                  • #24
                    It's already been cleared up, but here is another illustration on water boiling.
                    Your car cooling system can actually get well over the boiling point and yet the water doesn't boil because the system is under pressure. That is why you can remove the radiator cap while the car is hot and the water will begin to boil over. Under pressure the water would stay in liquid form, but when the pressure changes suddenly, it wants to convert to gas.
                    • #25
                      I'm gonna go ahead and say that by adding salt to the water you would raise it's specific gravity (above that of normal water). The higher the specific gravity the more BTU's required to change the temperature.
                      Okie
                      • #26
                        http://www.youtube.com/watch?v=dIZmU-QESFg
                        This may relate:-)
                        • #27
                          Just the facts Ma'am.
                          • #28
                            And now I'll hijack.
                            when water is put in a vacuum, it's boiling temp is lowered. Think cavitation. Pumps, boat propellers, etc.
                            • #29
                              if you have a tub of ice and water in it and add salt to the water you will chill cans of soda and beer faster
                              they did it on myth busters
                              • #30
                                Wait a minute! You boys actually boil your own water?
                                Your cooked food doesn't just miraculously appear before you on a plate?
                                I love my plumber
                                "My Hero"
                                Welcome, Phoebe Jacqueline!
