7/16" Supply Tube Needed :-(
  • 7/16" Supply Tube Needed :-(
    I have a Case of lovely 1/4 Turn Stops only problem the outlet is 7/16" (The Ferrell Slides perfect over the Void area of a 7/16" Bolt)
    or could it be metric ?
    any body got a solution ?
    Dave
    Re: 7/16" Supply Tube Needed :-(
    Change the angle stops.
    OR
    Go to the supply house and have them order you a few 6' sticks and a ridge tool
      That would be two 7/16 friction rings preceding the nut (a total of 4 per supply line) and a lock ridge tool.
        But he said ferrule.
        If he had friction rings he could use 1/2" FIP flex...
        GNO?
          7/16" copper used to be more common. Saw it on some dishwashers, etc. Hard to find fittings now, but they are around.
            Fairly New 1/4 Turn stops ... I am going to Get copper tubing / bore out some sweat in faucet ends and use 'em that way ...
            dave
              Dave
              How many in the case? What brand? What is the part #.
