Sump Pump Hammering
  • Sump Pump Hammering
    I have a problem. When my customer's sump pump turns off, it jolts the house. Does anyone have a clue how I can stop the jolting? Should I strap the pipe tighter or let the pipe move more freely? Anyone have a suggestion?
    Also, was wondering why someone would drill a hole in the pipe between the sump pump and the check valve?
    mark
    Re: Sump Pump Hammering
    The pump needs to be strapped tighter and more secure. The hole allows air to escape in the case that the sump is pumped dry. This prevents the pump from becoming airlocked.
      Ever try one of these?
      http://www.aymcdonald.com/geninfo/aymc_silentsump2.pdf
      I've never used AY Mac's, but have used others and they make a world of difference.
        does it have a brass or plastic check valve i have had to strap the pumps down and replace the brass checks with plastic
        Mike
        www.plumbinginclarkcounty.com
          Thanks everyone! I appreciate this (even though it took me a while to get back)!
            I use "Quiet Checks"
              Yup Me Too!
              They work!
              That link above is your ticket!
              They also make them for sewage ejector pumps.
              411 Plumb Appliance Stimulus Package
