concrete anchors
    Re: concrete anchors
    AGAIN THANKS MEN FOR YOUR INFO!!!THIS IS A SUSPENED SLAB SIMILIAR TO A CARTON FORM SLAB,BUT THEY USED METAL TO HOLD THE CONCRETE ON TOP OF THE GRADE BEAMS AND PIERS. I AM BIDDING TO REPIPE THE SANITART UNDER A EATERY, BECAUSE THE HACK THAT DID THE NEW JOB JUST HAVE THE PIPE FLOATING ON TOP OF THE GROUND. THE VOIDS ARE LEFT UNDER THE SLAB TO GIVE THE GROUND APLACE TO GO WHEN THE GROUND EXPANDS AND CONTRACTS. THE GROUND HAS MOVED ENOUGH TO PINCH A PIECE OF 4" PVC CELL CORE ALMOST COMPLETLY IN TWO.I AM BIDDING TO REPIPE AND HANG THE PIPING PROPERLY AND GET IT OFF GROUND LEVEL AS MUCH AS POSSIBLE. THE WET CONDITION I REFERRED TO IS #1 THE PIPE MOVEMENT CAUSED LEAKS ON THE SANITARY,#2 INFILTRATION WATER DUE TO THE MASSIVE AMOUNTS OF RAIN WE HAVE RECIEVED IN OUR PART OF THE WORLD. THANKS AGAIN MEN.
      does it look like this?
        I would drill ,blow out ,and set rod with hilti epoxy. I do earth quake retros,and have air and squeeze guns. VERY STRONG ! I'm from Boston,there were idiots running that job!
          If it is "Robinson"(Arthur's diagram) decking he would loose his a$$
          The drill bit would slop around like an egg beater in a bowl of brownie mix.
          On every hole he would have to use his point bit to pin/poke penetrate the metal then swap over to rotary hammer bit to finish his hole.I like shooting it,the steel grabs the pin better.
          Also,inspectors get real upset when you drill or shoot anchors into the "Ridge" portions of the Robinson decking.
          All hangers should be set in "Valleys".
            Drill or shoot.Better make sure you can do either/or throughout your workday.Nothing worse than unnexpectantly not being able to put up any hangers after 7:00 A.M.
            I don't know...Might affect your price
              ...the steel grabs the pin better.
              Actually, that may not be true, at least going by the specs Hilti has in their spec sheet
              (see table on the top of page 4 of the PDF in my previous post). The shear load may be
              the same or higher but depending on the embedment, the tension load is significantly less.
                If it is like the pic above with bar joist then I would use beam clamps.
                Here is a pic of my DX600N with the cup used to get in the valleys of corrogated metal decking.
                G3
                • #23
                  G3
                  this is what i was getting at. if there are steel joists well you dont have to drill at all there are so many ways to hang rod and rod connectors off the steel that all youd need is a wrench
                  • #24
                    Thanks yall for your replies. No my application doesn't have bar joist, it is like a metal decking material that they pour concrete over. Dirty hands thanks for mentioning when you can shoot anchors, but this will be a complete shutdown, for the duration of the job.
                    • #25
                      corrugated concrete pan?
                      • #26
                        not pans but sheets, used for pour in place floors or ceilings. Common thing around these parts.
                        G3
                        • #27
                          JW3
                          A picture of the bottom side of the deck would help us in our efforts to help you.
                          • #28
                            are you referring to robertson decking?
                            • #29
                              Might your deck be one of these?
                              http://www.metaldeck.com/floor_deck.htm
                              If so, this thread might apply:
                              http://forums.mikeholt.com/showthread.php?t=97117
                              • #30
                                Yes its coragated decking mamterial.
