concrete anchors
  • #31
    Re: concrete anchors
    Originally posted by Bob D. View Post
    Actually, that may not be true, at least going by the specs Hilti has in their spec sheet
    (see table on the top of page 4 of the PDF in my previous post). The shear load may be
    the same or higher but depending on the embedment, the tension load is significantly less.
    Thank you for the info Bob.
    When shooting into Robinson,due to the steel, I find a lot less pins have to be replaced do to the previous ones not "embedding" properly.
    • #32
      And make sure the plumbing inspector does the whole 160 ft crawl in the Mud ,the Blood
      and the Beer! As johnny Cash once said.
      • #33
        Originally posted by JW3 View Post
        Yes its coragated decking mamterial.
        FYI also known as a deck pan
        • #34
          Worked on Hi risers in S.F.. We refer to this as Q decking. Being a welder ,Id weld a 2"x2"
          square plate with 3/8" nut welded to it. Every ones different. 7014 won't burn through
          • #35
            You tacked the fish plate to the Q deck (we call it Q deck here too)? I've seem something similar done but the plate was suspended above the bottom of the trough in the deck on top of the rebar or supported with chair rails allowing concrete to flow completely around the plate.
            How does that make a connection to the concrete with any strength? It would seem (unless I am not understanding how this is put together) that all the load is supported by the decking.
            John Ruskin (1819 - 1900)
            • #36
              I don't know where this is, but ABS was the original material choice. I guess that's OK for Comm. work in that Hood. Consider what holds 4 " ABS on any wood frame home .
              Do You think Two 2" runs of weld on the decking to 3/16" plate, has less strength than a 10Dnail and a Plastic Hanger ?
              • #37
                i haven't seen abs on anything new other than trailer houses is 15 yrs. yes, pvc is allowable in my hood homie.
                • #38
                  Re: CLAY anchors
                  Ain't cast or pig iron ! Where was the plumbing inspector i st time around? [laid in the dirt]
                  Think He'll show this time?
                  • #39
                    That depends on where you take him to lunch at
                    G3
                    • #40
                      thanks again yall. cast iron is only required here when dwv is in a return air. again i am in small town USA( UNDER 26,000PEOPLE)
