Can't decide
  • Can't decide
    I can't decide if the original installer did a poor job or if the foundation settled.
    Don't see evidence of foundation damage though.
    Service main I corrected recently.
    Re: Can't decide
    looks to me like the plumber lifted it up to solder and it kinked against the foundation nice quality work there
    Mike
    www.plumbinginclarkcounty.com
      Re: Can't decide
      That's a backhoe tooth gouge
      Was the sewer repaired near that location?
        Re: Can't decide
        No. It was under the foundation and this was on the interior edge where I dug it out with a shovel.
          Re: Can't decide
          Need some more info JC
          Was it leaking? doesn't look like it.
          How did you find this if it was buried?
          Those scraps on the copper are recent. Notice the shiney marks. Definately not from original installation.
          Ok, if not a backhoe tooth maybe a pickaxe
          Interior?....waterproofer guy been through there laying drain tile?
            Re: Can't decide
            Wasn't leaking.
            Was wet around the yard. The homeowner decides to dig where he thinks a water line is leaking. I confirm and show him that he does not have a leak at the meter. He wants to see the actual pipe. He never made it to the pipe to damage it. I dug it out, found this, and showed it to him. He says he does think that water pressure is lacking. I tell him correcting this may help and also show him galvanized piping that probably should be replaced also.
            The "leak" is surface/groundwater that I tried to explain to him before I started digging. The sewer exits another area altogether.
            All indicators are that it is from the original installation. Maybe I cleaned it some and just forgot.
            I didn't hit this pipe at all while digging it out.
            No draintile. That's what I told him he probably needed from the start!!!
              Re: Can't decide
              I thought it looked it looked familiar but couldn't put it together until Bill said it. See the similarity.
              http://www.ridgidforum.com/forum/showthread.php?t=19975
                Re: Can't decide
                Yessir. And trust me I've been in the ditch when the backhoe has hit just about everything you can think of.
                And Bill is right, it DOES look like a backhoe tooth scrape but there no history to say so.
