New Water Heater Code
  • New Water Heater Code
    Getting Interesting ... 110 Degree tempering Valve ... ( Sooo Why Not Do away with Pressure Balance Valves ) Also The water will Be awfullly chilly by the time It Gets to The Fixture ...
    Also Expansion Tank ... Explain That to The Lady in a "Park Model" With a 10 Gallon Heater and NO Cabnet Space LOL ...
    Dave
    Re: New Water Heater Code
    Dave
    Where is this coming from? Proposed changes to IPC or UPC?
    110°F is the perfect temperature for Legionella to propagate.
      Here in Queensland Australia we have to use a tempering valve set at 49 degrees C in the hot water line,the laundry and kitchen are exempt from this
      by-law so we usually fit the valve in the vanity cupboard of the bathroom so the water basically cannot scald children,although there are a lot of plumbers who just "temper" the whole house for simplicity and cost saving
      Cheers
      Graeme
        It's in the 2007 Florida Building Code ...
        Dave
          I guess the only way to safely make Floridas new rule work would be to keep the WH @ 140 then add a tempering valve at each fixture?
          I see this as another case of the "Obama will save you" government mentality...
          I'm gonna bet that the numbers of scalds does not support a rule like this.
            Keep it simple. Cold showers work for Me! Hot water is a luxury.
            The Middle Ages, 1000 Years without a bath! Got an A in history, 1956, for that line!
