Weeel isin't This SPECIAL !!!
  • Weeel isin't This SPECIAL !!!
    Here we go tunneled 12' under a House and Found This ... Got to cut it out and Re-do in PVC .... The cou'de Gras (sp) is a sanitary T on it's Back smack dab up against the Bottom of the Slab !!! (Vent Stack) Trying to figure out How to Cut it out !
    What's This Job Worth ? ................................. Dave
    Re: Weeel isin't This SPECIAL !!!
    i have a new appreciation for what you guys do down there.
    Vince
      Are you under a slab????
      Be careful!!!!
      G3
        Yup Under The slab
        I keep a Piece of 3/4 Pex Which leads to the outside World Under my Arm Pit ... "Just in Case"
          Not enough.
            You're crazy and not in a good way.
              a bit narrow, huh?
                If the worst happens and you have to use that pex for breathing, remember that you can't inhale and exhale through the pex. Inhale only with the pex and exhale away from it.
                When seconds count, the police are only minutes away.
                  I'm sorry but I have to call flag on the field. If I understand this correctly, a master plumber with 30+ years experience is going to tunnel 12' under a house, weakening the slab, then ask the forum what he should charge which he doesn't know because he hasn't figured out how to fix the problem. Did I miss anything because I just to make sure I understand the situation correctly.
                    That makes a lot of sense. You would be breathing in your own carbon dioxide you put in the pipe, right?
                    Thanks, hopefully I'll remember that if I'm ever unlucky enough to be in that situation.
                      Lenny, I hope you won't put yourself in that situation to begin with.
                        Every poster here should tell you the same thing. STOP, DON'T EVEN ATTEMPT IT. What are you thinking?
                          Gear here is the Deal ... The 4" will be snap Cut No Problem ... Already Did the Cuts on the Small stuff ...
                          Will Probably Have to Cut the San T at the base of The Stack With an angle Grinder Then reline the 4" stack with 3" (Nothing Enters the stack)
                          As far as Pricing goes Will Probably Go Time and Materials Then Throw in about $250.00 For All the Sand packed in every Crevice ... Ears Hair Face Mouth Etc ... + general Aggravation ... Just Wanted to get a Consensus of the Group ...
                          Dave
                            I wish you the best of luck and be safe. Just throwing out some crazy idea, why not just cut the slab.
                              No under slab for me. Tunnels are for the others.
                              Especially one that narrow.
