Grey Water Tank??
  • Grey Water Tank??
    I have 1972 Land Yacht Trade Wind, 25 or 27'. When I run the sink water comes out the discharge hook up tube in the back? I have been told that Airstreams this old do not have grey tanks, and that I need a tote. but I have also heard of trailers with two tanks. How do I find out if I have an auxilary tank with a leak, or just no auxilary tank. Thanks.
    Re: Grey Water Tank??
    Wow,
    you are a persistent bugger aren't you? If you really are a plumber, can't you troubleshoot this yourself?
      If you have two tanks you will have two separate handles to drain the tanks (one for each tank). If you only have a single handle you only have a single tank.
        just crawl underneath and look? Just about every RV/Camper I have seen has had the tank/tanks visible underneath. or else just google it. There must be a bunch of Airstream forums out there that could easily tell you the specs of your rig.
          I had a 40' Royals Internation 5th Wheel and you had to tear the bottom apart to see the tanks.
