Why valves fail
  • Why valves fail
    how many different types of valve failure can you name.
    - half-closed/throttling (gate valve)
    - wire draw
    - wrong pressure rating
    - wrong application
    - improper installation
    - vandalism
    that's all i can think of.
    Vince
    Re: Why valves fail
    We have valves too ( circuit breakers). They trip (fail) from over voltage (shorts). But we can reset 'em.
      Re: Why valves fail
      mineral deposits that build up in the valve,
      Corrosion
      stupidity, (putting a pipe wrench on it and turning it the wrong way),
      and Freezing is another winner,
        Re: Why valves fail
        I get the strangest looks when I tell people to exercise their gate valves.
          Re: Why valves fail
          The acid in the $hit plants, eats em' no matter what there made from, also abrasion from grit in high pressure applications just destroys valves and direction changes.
            Re: Why valves fail
            Cavitation.
              Re: Why valves fail
              Gate valve packing nut leaks, for years, corroded to kingdom come!
                Re: Why valves fail
                Long ago, before nuvistors and transistors, before the IC, 'valves' in electrical service were made of glass and also known as tubes.
                  Re: Why valves fail
                  anybody know what the electrical equivalent is to a check valve?
                  Vince
                    Re: Why valves fail
                    Diode?
                      Re: Why valves fail
                      Yep a diode. I do miss working in electronics. I used to work in electrnics back in the day when the 7400 seres ships where commen place in the world.
                        Re: Why valves fail
                        The deterioration of rubber in a valve can cause it to break down. Same with electrolysis if it is connected to an improper material. Thats all i can think of right now. Feel free to correct me if I'm wrong.
                          Re: Why valves fail
                          How about those smart guys that put gate valves in parking garages with the handle pointing downward so it will be easy to turn on and off. What they did not plan on was all the sediment that collects in the housing so the first time you shut it off the stem snaps with the gate in the closed position.
