This is why I can't sell more water heaters
    Re: This is why I can't sell more water heaters
    It's "source of ignition" not "flame" so even a spark from electrical switches.
    Like an automobile starter solenoid?
      P.S. I spoke to code enforcement for my state of Nunya and was told that if an FVIR test is done by any mfg. they will eliminate the stand requirement for that company.
      But the manufacturers have never done the test to my knowledge because they never deemed it necessary.
        The shut off valve is on the cold side, not the hot. Our inspectors can't figure out what they want to see for an electric water heater. Some want it on a stand, some don't. The way I read my code book is that the water heater should be on a stand, but to be honest, if I replace one that sits on the garage floor, I usually don't install a stand.
        I used to do a lot of work for this property management company, but since Home Depot opened in my town, there handy men (and I use that term loosely) think they can do more. I haven't installed a water heater for them in months.
          So Utah,
          You'll be supporting me in my proposal to the building officials that all garages be built with car ramps at 18" elevation.
            So Utah,
            No but I might come along and giggle a little.
            Part of this has to do with fumes in your garage collecting while no one is around and then being set off by an automation source of ignition. They wouldn't have to worry about my garage as it hasn't seen a car in it in over 20-years.
              Originally posted by Nevada plumber View Post
              I came across this beauty at a four plex I worked on today.
              The original water heater was a fifty gallon electric, and I am pretty sure this is just a thirty gallon to feed two and a half baths. I know that either the property manager or the owner said get the water heater replaced as cheap as possible. A couple of trips to Home Depot by a couple of so called handymen, and now you have a water heater again. Who gives a crap if it is a horrible install, it still heats water, right?
              Stuff like this pisses me off to no end. There is no way to compete with crap like this. The town doesn't give a crap about this stuff either. I just needed someone to rant to, and figured this would be a good place to do it.
              its ugly for sure BUT other than using solid copper to plumb it and put a strap on it. How else would you do this? its pre-existing so you sorta have to put it back where it was no?
                Who cares...
                You have twice an investment in bikes and equipment.
                Who wastes perfect storage area on a car anyway.
                Poor Nevada...You O/K?
                Little drift my friend.
                Good thing he knows us.Someone who doesn't may get pissed.
                • #23
                  Arthur. It's poor craftsmanship all the way. Most tradespeople I have seen that are good at what they don't follow the path of "it's not leaking so it's fine".
                  I even look back at my own sometime and think I should have done way better.
                  • #24
                    The part which is not pre-existing is they installed a shorter heater so they added extra water flexes to the existing flexes. Then the T&P was in a different location so they added another flex to the existing flex on the T&P and trapped the line.
                    • #25
                      When you replace a water heater you must bring everything associated up to current code.
                      Buy the proper sized water heater. Run the T&P properly. Full bore shut off valve. ETC...
                      • #26
                        Yeah but they made one badazz-double-duty-paint-pan holder.
                        • #27
                          It's also wired direct to who knows where. Around here it's supposed to have a disconnect or receptacle within 3ft of the heater.
                          I bet that soon the gov will require all flammable liquids must be stored in a special ventilated closet.
                          • #28
                            oh yes i agree with you all here like i said about using solid copper and all that.
                            but as far as placement goes whould you have moved it?
                            • #29
                              The main problem I have with it is you cannot trap the relief valve drain line. If that ever needs to open up in a hurry and it can't, you have a potential bomb on your hands. It would have been better if they just got a sharkbite and put that on so the relief valve drain went downhill the whole way.
                              The other problem I have is it is harder to make my money installing water heaters when people don't want to have them installed legally. I tell people all the time that stuff is not done right and is a hazard, and I'd say half of them don't care. I am not the first plumber to have this complaint and I know I will not be the last.
                              • #30
                                Now I know why most local cities around here want you to pull a permit when you change the water heaters. Installs like that just amaze me. I just had a call from a lady that wanted a "Hybrid Heater" I tried to see if what she was picking out would be sized properly for her needs, she snapped back at me telling me she is an engineer and been researching this for the last 15 years. I said OK fine I give you an estimate, what town do you live in so I can figure in the permit fee. Wow did I touch a nerve with her. She goes off telling me the Town of Lisle does not require a permit to change out a water heater, and she doesn't want strangers in her home looking things over. Of course I explained to her what she is proposing to have done is not a simple change out, it requires upgrading the gas piping, running the vent pipes to the outside wall for the power vent. Then quoted her this paragraph from the city's website.
                                "A permit shall be required to install, repair, maintain, alter, or make additions to any and all piping, fixtures, appurtenances, and appliances connected to any water supply, and/or any storm water and/or sanitary sewage disposal system, including, without limitation, lawn irrigation systems and backflow prevention devices connected to lawn irrigation systems."
                                Well she went off on me,about how she does not want a permit on the job and such. So I just told her "I am sorry ma'am then I can not do any work for you. Have a good day" She was shocked and started to stutter, I then said " If you want this job done right and properly, and are willing to have it inspected please feel free to call me back, Goodbye" then hung up.
