Jetters
  • Jetters
    How do you use a jetter. Like the little Ridgids.Does it need a garden hose for water or can it hook up to an interior faucet to clean the drain in the wall. We are having repeat problems in a commercial building.
    Thanks
    Generally ,I run the jetters with a garden hose connection. I have in some cases run the jetter by hooking upo the hose to the faucet if the appropriate connection is available.
      Make a faucet adaptor with a hose, a female garden hose fitting, (brass not plastic) and 2 hose clamps. Put the garden hose adaptor and hose together, use hose clamp to secure the hose and adaptor. Slip the adaptor over the faucet spout, secure w/the other hose clamp. Tighten the hose clamp. Now you have an adaptor that fits 98 % of kitchen faucets.
