Is this right?
    Re: Is this right?
    I don't work on much commercial. Is this right?
    Looks to me like the dummy who did the work did not Know how to read a tape measure or maybe his/hers was metric!
      Re: Is this right?
      Did they install the vacuum breaker in there? That was a lot of thought to do the whole thing wrong.
        Re: Is this right?
        I know it's not right. But at the same time, I HAVEN'T worked on that many Sloans where this is the case.
        Suggestions are welcomed. The pic may not indicate it but the difference between the center of the valve and the spud is about 1-5/8". Don't know if an offset VB will even fit.
        The shutoff for the building looks VERY shaky. 2" gate valve from the 60's maybe.
          Re: Is this right?
          You are going to have to lengthen the nipple out of the wall or if it is a sweat type valve stop lengthen the copper pipe. So you will have to shut off the water to investigate. Sounds like a nice invoice.
            Re: Is this right?
            I know you're right.
            Was trying to avoid the potential nightmares.
              Re: Is this right?
              That is why you are THE PLUMBER
                Re: Is this right?
                Does it leak?...no?.... Problem solved
                The problem with extending the copper is; you have to make a solder joint back inside the wall or the cover tube won't fit with a coupling on there
                Best to try a offset vacuum breaker and be sure to use a chrome split ring hanger to support it. Lots of exposed piping hanging out there
                Might even be easier to just change the bowl
                • #23
                  Re: Is this right?
                  Get rid of the cover tube and use a sharkbite. Polish the brass like the Burger king Back flow preventer Rick posted awhile back.
                  • #24
                    Re: Is this right?
                    If you have to use an 1" copper coupling, chuck the cover tubing and escutcheon replacing them with an 1-1/4" tail piece and flange from your scrap bin. Should fit if you don't leave any dimples on your joints.
                    • #25
                      Re: Is this right?
                      Only if your an illegal..............
                      • #26
                        Re: Is this right?
                        pretty simple to use a sloan swet kit. the chrome cover casing will fit over the cxc coupling and it comes with the mip x c adapter that it too fits over.
                        if i remember correctly, it's been years you cut the copper 1.125'' back from the c/l of the spud and solder it on. don't quote me since it's been years, but i have done my share of flushometers
                        at least a few hundred
                        same goes with threaded brass nipples. the finished length should be about the same.
                        • #27
                          Re: Is this right?
                          Thanks Rick and others. It's been years for me too. And I didn't do even half as many. Seems like I do recall using a threaded slip x swt. brass adapter. I'm wanting to say it was slip through without stop.
                          Hmmmm......
                          • #28
                            Re: Is this right?
                            What a frickin' nightmare.
                            Con: illegal, unsightly, and ready to blow out and cause a flood.
                            Pro: it was done cheap
                            • #29
                              Re: Is this right?
                              Originally posted by Bogart;235879[B
                              ]What a frickin' nightmare.[/B]
                              Welcome to my world. I guess they would never call if it was easy.
                              • #30
                                Re: Is this right?
                                That's my world, too. My gig is industrial/commercial service plumbing. A lot of skilled mechanics have worked on the plumbing before I get there. Unfortunately, their skill isn't in plumbing.
