A little mistake, or was it ??????
  • A little mistake, or was it ??????
    Cleaning 3/4" copper fittings today on a project. You know the drill. I have a number of twisted wire cleaning brushes , i cut the handles off. I inserted a 3/4" one in My drill chuck.
    It was not quite centered in the drill chuck jaws. when I cleaned an ell it wobbled/
    Wow, what a difference! ABOUT A 50% improvement! I'll never put one in straight again.
    Please give it a try and let Me know what You think. Tool
    Re: A little mistake, or was it ??????
    You did not break your elbow trying to hold the drill...
    I wobble the fitting for the same effect without the drill bounce...
    okie
      okie
      Give it a try!
        I actually stopped buying 3/4" turn brushes about 15 years ago.
        I use sandcloth for everything, does the same job.
        I do use a 1/2" turn brush because it hurts my fingers to try it on 1/2" hubs.
        I have yet to ever find a turn brush that wasn't intentionally made to wear out so fast.
        The cheapest I've found is $1.73 for 1/2".
          I keep a 1-1/4" brush with the wire handle cut off for Sloan valves with a drill. Dresses 'em up nicely.
            This brings worn ones back to great service
              I can see that working real good then.
              Glad to hear you're still working with the "good" stuff.
                I use the Next Size Up :-) 3/4 on 1/2 etc ... 'Cept my last Job ... See my Post on that one ...
                Dave
                  Thanks,copper is good! Always type L and REAMED! M is for domestic heat only.
                  Sorry children,I was taught better
                    you can also spin the fitting brush backwards to get a little more life out of them in a pinch.
                    Vince
                      thowing it into reverse also brings the brush back to life...
                        Thanks Tool,I'll be giving it a try on the next large quantity fitting run.Not a lot of big count right now.Catch me's drift?
                        Out of convienience I have been using the course loose wind brushes sold at Ferguson's.I think I can get through a hundred sockets,give or take.The Home Depot had some finer,tighter wind that would hold maybe twice as long but weren't worth the money.
