kohler Waterhaven k-498
  • kohler Waterhaven k-498
    A customer has a problem with the system. Whenever they turn the water on, and start mixing the hot w/cold the hot 3/4 water line begins to vibrate until it sounds like a freight train is going thru the house. In the past, the valve has been rebuilt, that did not help. Kohler says to make sure it has arrestors/air chambers. Of course those are in the wall, tiled behind the heavy, bolted unit. Kohler sent out a rebuild kit again, but my gut feeling is that is not the problem.
    Something is not right...
