This is nutz
  • This is nutz
    Got a call this morning from a local beverage dispensing establishment, owner informed me the toilet was broke last night and could I get to it today.
    I show up and this is what I found...
    www.uandiplumbing.com
    Re: This is nutz
    some of the other things that have been keeping me busy...
    I do love my job...
      Re: This is nutz
      hard to say, but i see nothing wrong with this unless that's pvc on the t&p.
      out here in quakeland. this is not only the standard, but pretty much the requirement. of course i would use brass nipples and not gal.
      venting is screwed and secured
      of course i can't see if there are upper and lower seismic straps and a flex on the gas
        Re: This is nutz
        I understand the need for that kind of thing in quakeland, but the part of me that likes clean lines and hardpipe still kind of shundders when I see it.
        we have guys that use those water heater flexs with pex barbs on one end. it makes me want to cry.
          Re: This is nutz
          The last time I saw a toilet look like this, I had just tossed a M-80 in it
          Remember, ALWAYS check the seat before you sit down
            Re: This is nutz
            there is a bar i seem to get a late night phone call from 2 times a year. typically it's a brawl that ends up with a broken toilet, urinal or a wall hung lav that's not wall hung anymore.
            what held the tank up is amazing.
              Re: This is nutz
              C'mon Rick, look a bit harder, I was called out to this because of insufficient hot water, some bone head piped the cold supply into the relief opening and vise-versa.
              The picture is facing the front of the unit.
              Took me a few minutes to realize what I was looking at.
                Re: This is nutz
                I hope you sold them a new w.h....
                (The Low Spark of Steel-Toed Boys)
                  Re: This is nutz
                  nope, those are the tactics that my competitors are using, which is why they are starting to languish behind as I am steadily doing more work each month, at the end of this month I will actually have a phone book ad, 9 months without the phone book and gaining ground each and every month.
                    Re: This is nutz
                    I replaced a toilet at a restaurant once that looked like that. One of the employees had tried to put a new lid on it and used a hammer lol,. Needless to say that didn't work to well.
                      Re: This is nutz
                      That wh looks old....10 years old?
                      The customer paid you to correct the mistake and very soon will pay again to replace it. I would have replaced it and saved the customer money in the short run.
                      Did you replace the toilet bowl and re-use the tank?
                      Besides, I do this thing to make money. I haven't raised prices since 2007 when the problems started, but I do this to make money. If I'm not making money, I may as well be a full time forum bum.
                        Re: This is nutz
                        I believe there is a vent issue also on that water heater. In my area you cannot run dual wall pipe straight to the flue, you need vent connector pipe in between and you are not able to screw dual wall toghether.
                        That is a dual wall fitting coming off the flue correct??
                        Robert
                          Re: This is nutz
                          I was called to fix the problem and so I did, plenty of hot water avaliable now.
                          I'm in this to make money also, but I am not about to sacrifice my morals to make a buck on an un-informed owner, that is just wrong and why we as a nation are in dire straights today, to many used car salesmen screwing with our trade. If the tank is not leaking there is no reason to replace, period.
                          In an area the size I service, high pressure sales types don't last long in the service game, they are rooted out and exposed for what they are and slowly die away.
                          The ONLY time I push to replace a water heater that is not leaking from the tank is when I find the old square bolt pattern elements.
                          as far as the venting is concerned it is the domain of the tinner, not my call.
                            Re: This is nutz
                            That vent 90 looks single wall, but with the piece of paper on it, its hard to tell. I'm not good with internet photos. You did remove the paper?
                            People expect to spend money when they call a plumber. I bet that your customer fully expected to get a new, high efficiency water heater and all they got was a repair on a piece of crap American that probably knocks as loud as a New Orleans SWAT team on a Saturday night.
                            I'm not a handyman and my training, years of experience, licenses, and attitude reflects it.
                              Re: This is nutz
                              i noticed it still has a "water" seal. the tank is amazing also. breid
