Jack Screw on Tristand Pipe Vise
  • Jack Screw on Tristand Pipe Vise
    I have always wondered what the jack screw on a tristand pipe vise is used for. Can someone please explain the jack screw to me? Thanks for any help.
    The screw is used to support the tristand. 1" pipe is cut to length and propped against a joist or surface above the tristand. As the screw is turned, it pushes the pipe against the ceiling and causes downward pressure on the tri-stand holding it securely in place. I hope this helps.
      I had the same question about that.
      I thought I was the only clueless about the jack screw.
      Thanks for the info.
      A Ridgid Fan.
