Water heater flex connector goo
  • Water heater flex connector goo
    had a customer that called me complaining about "black goo" in their bathtub when they use the hot water.
    i diagnosed it over the phone and went there to replace the faulty stainless braided water heater flex connectors.
    turning on the tub surprised me at how much of this dissolved rubber was present in a large surge. the reason why only in the tub, it's the only fixture that is not flow restricted.
    there were issues when these connectors first hit the market in the early 90's. they did have this problem of the rubber breaking down, especially on the hot side. i was surprised to find them on this customers heater this late.
    then came the newer replacement braided flexes and they had overcome the rubber dissolving, but instead they failed at the crimped joint years later.
    so now the newest and i think the best of the connectors are the corrugated stainless steel flexes. real flexible and easier to bend than the traditional copper flexes.
    remember that in california we have earthquakes to worry about. flexes allow for heaters to move without the piping being twisted and kinked.
    a very small sample of the black goo. the tub was covered in it once the fresh hot water entered.
    notice the tight bend/ kink at the hot side connector. please note this heater was moved out to the garage about 10 years ago. appears it was never inspected based on the venting.
    upper left is the hot connector. upper right is the cold and lower is the new corrugated stainless flex.
    the hoses have brass barbs that are crimped to the hoses. notice the mineral build up and smaller id.
    new stainless flexes. 18'' was too short and 24'' provides a nice smooth bend and will absorb seismic movement.
    Re: Water heater flex connector goo
    Rick, are the braided SS hoses I see in the first pics from Watts?
    Who makes the corrugated flexs you used?
      i have to go look at them, but i don't think they were the watts brand.
      the corrugated ones are "rhino" as the "falcon" brand is not annealed and too stiff.
        Thanks Rick, couldn't tell from the photo whose make the corrugated flexs were. They are not commonly used around here. Most times you will see the SS flex hoses installed (if any).
          I replaced a 2 year old braided flex this week because of rubber breakdown. The newer braided flexes won't break down due to chlorine, but they still have a problem with chloramine on the hot side.
            I was just going to post about the chlorate on the hot side breaking down rubber washers. I see it a lot on angle stops at restaurants, with really hot water.
              Rick -
              Why does the flex you installed on the cold side have a small, straight portion on either end?
              I'm not a plumber and am guessing it's what you had on the truck?
              -----Mike
                Are you replacing them with 1/4" ceramic disc stops???
                  Nice picture, I learned something new today!
                  I have never seen this before ;-)
                  Rick, Thanks for the post man !!
                    Some of the non- plumbers need to be aware that while the flexible connectors are necessary and approved in CA. and maybe other states, they are violations of the plumbing code in many others, and not desirable to boot.
                    Simply because an item is sold at the big box stores does not make it code acceptable or even safe for that matter.
                      Originally posted by Nature_Photog View Post
                      Rick -
                      -----Mike
                      mike very good eye and observation
                      they are the same rhino brand. the difference is the newer ones have the non corrugated end and the older ones have all corrugation. also the newer ones are larger corrugations.
                      carry both the 18'' and 24'' in stainless and 12'',15'',18'', and 24'' in copper.
                      good call mike
                        Whatever Brasscraft makes, I don't know if it's ceramic or what inside. They are all I keep on the van.
                          So true,union plumbers are soo smart! Amazing We can find our way home
                            Had this in My own home. Bought the problem with it.
                              [QUOTE=PLUMBER RICK;241312]mike very good eye and observation
                              good call mike
                              rick
                              __________________________________________________ __
                              ----Mike
